Re: need opinions on clutch issue SC
Posted by mkirsch on April 24, 2009 at 04:48:12 from (64.80.108.55):
In Reply to: need opinions on clutch issue SC posted by Jonathan William Mirgon on April 21, 2009 at 18:28:26:
I had a similar problem with a Cub once. Adjusting the clutch fingers through the hand hole in the bottom fixed the issue. All it took was 1/4 turn of the adjustment screws to allow for more lift on the pressure plate.
Since you're presumably not going to work this tractor daily, it shouldn't be necessary to tear it down again to replace the pressure plate and machine the flywheel. The clutch won't last as long as far as operating hours go, but it'll likely last you the rest of your life.
