Re: 1958 350 Utility PTO Addition????
Posted by Chris Walls on April 25, 2009 at 04:27:38 from (71.55.85.178):
In Reply to: Re: 1958 350 Utility PTO Addition???? posted by Janicholson on April 24, 2009 at 19:40:34:
Just checked the CNH parts site for more info and am more confused! There are listings for IPTO and TPTO with the TA. Under the TA breakdown there are parts listed to be used with an IPTO. Can I assume that these parts are already in mine? Not sure how the internals were done when a PTO was not optioned from the factory. I have removed the PTO cover plate from the rearend to look around. There is a splined shaft extending from the transmission into the rear end housing. It appears to be were the coupling would hook up for the IPTO. Also what fluid was used in the rearend, is it shared with the trans/TA. I drained apx 6-7 gals out of it. Smells like gear oil but I have heard HyTran should be used in these areas. Thanks in advance. Chris
