Re: 1958 350 Utility PTO Addition????
Posted by D Slater on April 25, 2009 at 10:20:45 from (71.182.22.233):
In Reply to: Re: 1958 350 Utility PTO Addition???? posted by D Slater on April 25, 2009 at 09:56:32:
Forgot to say you need the pto unit with a vent on top and a upside down bath tub shaped metal cover with one screw in the middle, cover is on right side top. If you could get the in and out shift parts a planetary pto from several tractors will work. One from like a 400 would need the adapter plate between it and trans. housing. shaft ahead of pto is the same for both size transmissions.
