Re: 300 hub ?'s
Posted by mkirsch on April 26, 2009 at 00:37:25 from (67.240.251.254):
In Reply to: 300 hub ?'s posted by Mark from WI on April 25, 2009 at 22:02:05:
You are correct. R indicates a minor revision to the part.
The difference probably isn't detectable, other than the part number.
Hopefully you've figured out that you can remove the wheel weight, turn it 1/4 turn, and reinstall it...
