Re: 300 hub ?'s
Posted by D Slater on April 26, 2009 at 06:20:24 from (71.164.44.188):
In Reply to: 300 hub ?'s posted by Mark from WI on April 25, 2009 at 22:02:05:
Probably the same thing found on some early 400 8 spoke wheels. They must have cast and drilled the wheels wrong. Instead of weight holes being squared with the keyway there off about 45 degrees. Also saw them with 8 holes drilled, with one set correcting problem, looked factory drilled or a good job by someone. 363019 R2 is a 300 wheel with a little more material added at hub. Later 300 started using wheel 364698 R1 which used a axle key separate from wheel.
Which one of your wheels is wrong. Ones I found on 400 were mostly cast in december of 1954. Sounds like your saying the later wheel is wrong on yours.
Today's Featured Article - Show Coverage: Fair Weather Tractor - by Dave M.. No, Fair Weather isn't some rare brand. It's the kind you can't leave out in the rain. Here's how it happened. I had been casually looking for a tractor for weeks. I saw a few 9N's, but they had even fewer amenities than the 8N my Grandpa bought new in '52 with a Dearborn loader. That was 10 years before I was born, so I grew up thinking that 8N was the world's best tractor. Grandpa had greenhouses, with over half an acre under glass, and that 8N did almost everything. It was the only ... [Read Article]
