Re: IH 300U Overheating
Posted by Dellbertt on April 26, 2009 at 07:31:51 from (209.172.22.5):
In Reply to: IH 300U Overheating posted by Matthew Williams on April 25, 2009 at 22:01:10:
Do the normal checks:
Radiator uniform temp top and bottom
Is the engine block uniform temp. No hot or cold spots on block.
Fan belt slight play only. but not real tight.
could be:
need better cap
needs new thermostat.(probable cause. available at most autoparts stores.)
system plugged somewhere.
regrease pump at fitting.
