Re: smta water pump packing nut
Posted by smtapaul on April 27, 2009 at 19:52:02 from (68.117.10.58):
In Reply to: smta water pump packing nut posted by smtapaul on April 27, 2009 at 11:28:57:
I called my local IH dealer a smart wrench in his time and he said that the only way to get to the packing nut is to remove the hood,grill and support radiator rod then pull the radiator forward to gain access to the nut.He did mention the spanner wrench but this is only for use on the Ms and super Ms. SMTA is just packed to tight wich I find hard to swallow a super M is a super M.But I could be mistaken.Paul
