Re: smta water pump packing nut
Posted by D Slater on April 28, 2009 at 18:37:16 from (72.65.159.3):
In Reply to: Re: smta water pump packing nut posted by smtapaul on April 27, 2009 at 19:52:02:
SMTA gas radiator is a greater distance from the fan and water pump than a gas SM. Also uses a deeper fan shroud than a SM gas, so the working room may be about the same. For tightening without removing parts. If the nut is not frooze up, Make something or put something that will fit in one of notches on nut and wedge agian one of the drive pins and turn fan in normal direction. Nut may be screwed in all the way already though. Another thing I do sometimes if I have fan and parts off and nut notches are messed up, is grind a flat on 2 sides of packing nut to the size of a thin wrench I have. If tightening is needed I put wrench in between drive lugs and turn fan.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
