Re: What tire size?
Posted by randy hall on April 28, 2009 at 07:45:50 from (209.143.0.64):
In Reply to: What tire size? posted by BruceS. on April 28, 2009 at 07:21:02:
99% chance that your rims are eleven inches wide. anything wider than 13.6 with look all puckered up.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
