What tire size?
Posted by BruceS. on April 28, 2009 at 07:21:02 from (76.15.46.195):
Want to replace tires on my "new" MD, and need some advice. I believe it has the orignal rims which I think are 12". Is this correct? I was thinking of putting on 15.5's or 14.9's, but would these sizes work on a 12" rim? OR should I just stick with the original size which was 13.6. Any advice appreciated.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
