Re: What tire size?
Posted by the tractor vet on April 28, 2009 at 07:52:12 from (75.19.124.161):
In Reply to: What tire size? posted by BruceS. on April 28, 2009 at 07:21:02:
Myself i think a 14.9x38 is a nice looking tire as the 15.5x38 is a short sided tire and they both need a 14 inch wide rim . I have split many rims and added a band to them and the 12 inch rim is easy to do . I myself made the mistake of putting 16.9x38's on my S/MTA just to go play with the boys . after i did it i hated the way it looked . One of these days i am going to pull them off and put the 14.9's on.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
