Re: What tire size?
Posted by D Slater on April 28, 2009 at 10:50:47 from (71.164.44.229):
In Reply to: What tire size? posted by BruceS. on April 28, 2009 at 07:21:02:
Guess it depends on the tire brand and what you have in mind. Just my opinion but I like the look of some 14.9 tires on 12 inch rims better that on 14 inch. Some 15.5 don't look to bad on 12 inch and some look like a balloon. Some 13X38 or 14.9X38 say on a 13 inch rim on the side of tire. When IH started putting 13X38 on some SM and 400 tractors they used the 12 inch most times. Never saw any but early IH parts books for early SM only shows the widest rim as 11 inch and tire options were 11x38, 12x38, 13x38. Prrobably if a customer wanted something else bad enough they may have furnished it.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
