Re: smta water pump packing nut
Posted by Kevin Meier on April 28, 2009 at 14:53:47 from (208.90.10.236):
In Reply to: Re: smta water pump packing nut posted by smtapaul on April 27, 2009 at 16:03:30:
I've been rebuilding water pumps and t/a's for 17 years. If you tightened the nut down and added packing and it still leaks? It probably needs to be pulled apart and replaced or machine the impeller surface and the landing surface it rides against so they are true to each other. I would also replace the bearings and seals if you need to do all of this. Water in those open bearings is not a good deal.
Kevin Meier
K & C Tractor Parts
