Re: smta water pump packing nut
Posted by Kevin Meier on April 28, 2009 at 14:56:41 from (208.90.10.236):
In Reply to: Re: smta water pump packing nut posted by Kevin Meier on April 28, 2009 at 14:53:47:
I also forgot. There are 2 springs that are under a T-Bar at the top end of the pump. Make sure the springs are still there. They pull up on the shaft and help keep pressure on the impeller surfaces I told you about.
