Re: Easiest way to reverse tire threads on a H
Posted by ScottyHOMEy on April 29, 2009 at 06:13:38 from (70.105.230.232):
In Reply to: Easiest way to reverse tire threads on a H posted by Spring Ridge Farm 1898 on April 29, 2009 at 06:00:31:
If width of tread is a consideration, and it's going to be the same width with both tread directions, and you can achieve that width with the lugs on the rims to the outside of the wheel, then I should think it would obviously be easier to lift the rear end and roll your tires and rims from one side to the other and bolt them back up.
That's not to say it would be easy if the tires are loaded. They will be heavy, maybe too heavy to handle by hand, but it's got to be easier than unclamping axles and moving wheels (and I assume wheel weights) and all.
