Easiest way to reverse tire threads on a H
Posted by Spring Ridge Farm 1898 on April 29, 2009 at 06:00:31 from (209.94.182.253):
I will be using my Farmall H for pulling and will need to frequently reverse the threads on the rear tires.
My question is which method would be easier to do this.
Loosen the two wheel clamps and slide the wheel assembly off the axles and switch or loosen the 6 clamps on each rim and then reverse the tire?
Thanks in advance for your answers/input.
