Re: Easiest way to reverse tire threads on a H
Posted by sflem849 on April 29, 2009 at 07:52:18 from (66.254.196.101):
In Reply to: Easiest way to reverse tire threads on a H posted by Spring Ridge Farm 1898 on April 29, 2009 at 06:00:31:
You are correct. You want the TREAD facing backwards for pulling on asphalt/concrete for two reasons. The first is better traction. The second reason is that it sharpens the lugs. This is important when you go back to pulling on dirt.
I have never taken just the rim off (while on the tractor), everytime I do it I swap the centers and all. It is simple. After you get your axle shafts cleaned up you can do it in about a half hour, maybe less! They aren't too heavy at all. BUT, if they are loaded you will kill yourself. If you start to lose one just let it hit the ground and pick it back up. It is too dangerous to try to save one from falling.
