When tenaco purchased IH , they already owned case as it had gone under years before. In the merger the equipment for mfg the power train of the IH 50 series tractor was moved to Racine. Then engineers from both sides of the isle built the magnum,(power shift was already in the works I understand). You will see ideas from both sides of the merger in that tractor. As far as the so called cummins engine, in 1980 or so, Case and Cummins entered into a joint 50-50 venture and developed the Consolidated Diesel Corp, and designed the new engines. It is totally different from the traditional cummins engine and the previous case engines. Cummins always used a PT fuel system which utilized unitized injectors run off the camshaft, and the new CDC engines is traditional inline unit injection pump. Both Case and Cummins engines rolled off the same assembly line with minor changes depending on which way the engine was going. The smaller CDC engine was being used in one of the case tractors at the time of the merger, never could get them case model numbers straight. After that many changes have taken place, the engine used in a Dodge for instance started out as that engine, as you will notice the six seperate valve covers. At any rate, when people say cummins, I think is appropriate to point out that there is actually two totally seperate styles of engines out there referred to as cummins when one is actually a CDC engine. I know the last years have changed the picture again and I don't keep track of them anymore but that is how it came about at the time Tenaco purchased IH.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
