IH 50 series to Case IH magnums
Posted by Larry B. 1486 on April 30, 2009 at 05:28:19 from (74.143.243.250):
I have always wondered if they designed the CIH magnums,7110,7120,exc, off the 50 series IH tractors,5088,5288,exc. The hitch parts, pto, some of the cab, front axel are all the some and someone told me the transmisson were practially the same just redesigned it into a fully eighteen speed power shift. After IH went out and tennico took it with case, did not they want to use the larger case tractors and IH implements but that about put them under also and they redesigned the tractors back to the IH pattern and the motors a cummins overhaul off the old 504 case motor and called it a 505? I always liked the looks of the 30&50 series IH's and the magnums do look close to them.
