Re: Tire Service: $432.50
Posted by glennster on April 30, 2009 at 11:26:01 from (75.57.116.97):
In Reply to: Re: Tire Service: $432.50 posted by John G. Hasler on April 30, 2009 at 10:26:54:
john, i do all my own tires, and do my own fluid too. not real hard. i use an old 200 gallon poly tank to pump the fluid in and out of. two tire spoons, and i use a handyman jack and a chain to break the beads. for a pump, i have a 12v marine washdown pump, but and electric sprayer pump will work fine as well as the 10 dollar drill operated pump from home depot. napa can get the tire fill adapter kit, prolly under 20 dollars. napa can also get the heavy duty truck tire spoons. lot of guys dont like the handyman jack for bead breaking, but my right shoulder is screwed up and i cant swing a tire mallet anymore. i take the tire and rim off the tractor to break the bead, do it flat on the ground.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
