Re: Cub crank pulley
Posted by Andrew Z on May 01, 2009 at 06:09:16 from (64.252.181.197):
In Reply to: Cub crank pulley posted by Chief 83 on May 01, 2009 at 05:57:54:
put the pulley on a wood stove or in a range that will heat it up enough to slip it on. be ready with a block of oak and a 3lbs hammer to finish the last inch or so if needed. as for the seal put a liberal amount of greese on it and it will protect it from the heat.
Andrew
