Posted by badge311 on May 02, 2009 at 06:47:24 from (69.179.112.196):
I spent the winter fixing up my "39 Farmall A. New carb, rebuilt the mag, new plug wires. It still won"t start hot. It starts easy when cold and purrs better than ever. The problem is with the throttle adjustment. When off you can push the throttle lever forward and the governor adjusts the throttle plate accordingly. Once you started it runs at the same rpm"s no matter where you adjust the throttle lever to. Any help would be greatly appreciated. Thanks.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
