Re: 1939 Farmall A
Posted by gene bender on May 03, 2009 at 04:57:41 from (67.55.227.59):
In Reply to: 1939 Farmall A posted by badge311 on May 02, 2009 at 06:47:24:
Have you set the linkage correct and did you overhaul the gov housing when you were working on the engine.Input lever gets worn and mite need the spring installed with the hooks facing out on the spring. Your problem is probably there.
