You have A CLASS A CHARGING SYSTEM so the purpose of the VR is to supply A GROUND FOR THE GENNYS FLD POST either a dead ground for high max charge or a resistive or switched (relay chatter) ground via a field current control relay.
Some Fords used a Class B system where the VR supplied voltage to the Field BUTTTTT you have an A system. The gennys FLD post needs a ground NOT a voltage source on that A system. Likewise a B generator (some Ford products) has an internally grounded Field. Your A type genny has its Fields input connected to the ARM terminal and it terminates out the FLD post where it gets a ground either via a VR or a LHBD light switch.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
