Posted by Melvin Ware on May 02, 2009 at 11:53:42 from (4.152.108.198):
I recently acquired a 1951 Farmall M with 12 volt electrical system (negative ground) on which the generator has never worked. I finally found some time to troubleshoot the problem and traced out all wiring which looks to be correct. However, I have no voltage to the field terminal of the generator. Examining the voltage regulator internally, I find the "F" terminal which feeds the field terminal on the generator actually connects to ground - either through a contact or through a resistor internal to the regulator. No way this can supply the necessary field voltage to the generator! So I'm wondering if someone has either put the wrong type generator or the wrong type voltage regulator on this tractor? Any suggestions on how to best correct this would be much appreciated. Also, does anyone know if this tractor originally had a 6 volt system?
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
