Re: Farmall M Voltage Regulator
Posted by Owen Aaland on May 02, 2009 at 15:36:51 from (65.174.247.96):
In Reply to: Farmall M Voltage Regulator posted by Melvin Ware on May 02, 2009 at 11:53:42:
Just a slight correction to the circuit description. Since this is a three brush generator, the internal connection of the field coil is to the third brush instead of the A terminal.
It still works the same but, with an adjustable third brush, it is possible to adjust the charging rate by adjusting that brush. Having the brush set too close to the A terminal brush cause overcharging and over heating of the generator. Later generators had a non adjustable third brush.
