Re: No 1 plug mis-fires when warm? on a 140?
Posted by Clean John on May 03, 2009 at 06:26:36 from (216.228.193.227):
In Reply to: No 1 plug mis-fires when warm? on a 140? posted by NawlensGator on May 03, 2009 at 05:23:13:
Nawlens- Not familiar with 140 -Is the electronic modular unit separate from the dist? If so try isolating from any engine heat source --sounds like you have heat sensitive component failure in your ign.mod.This is not an uncommon occurance.CO2 sprays on dist housing might also work if mod is internal--hope this helps.--John
