Re: H won't turn
Posted by Baelee05 on May 03, 2009 at 06:50:55 from (66.82.162.20):
In Reply to: H won't turn posted by Bleeker on May 02, 2009 at 21:44:58:
A few things come to mind. Did you do the overhaul yourself. If so, did you double check all clearances on your bearings? If your clearances are too tight it makes for a tight engine and trouble if you ever do get it started. Secondly, did you lube all your parts well when reassembling? This makes a huge difference too. If someone else did the rebuild I would talk to them. If they are confident about the clearances then proceed to get the heaviest cables you can and the stoutest 6V battery you can lay your hands to. Do you have a hand crank for the tractor? If so you should be able to turn the thing over with the plugs out.
