H won't turn
Posted by Bleeker on May 02, 2009 at 21:44:58 from (70.92.185.46):
My H engine rebuild is done but I won't get the tin and a few other things done for awhile. To day I installed the starter since I wanted to hook up the new battery and make sure the starter works OK. The engine was not running when I bought the H. I put a new bushing and bendix in it and it turns strong on the bench but it won't turn the engine over. It will only it turn a few degrees each time I engage the starter. It is 6 volt and I am using a pair of fairly small gauge jumper cables to hook up the battery. Could this be the problem. Also, the engine seems a little tight. I can barely turn it over with my hands on the crank pulley with the plugs out. How tight should it be??
