Re: No 1 plug mis-fires when warm? on a 140?
Posted by TheDurk on May 03, 2009 at 07:12:20 from (72.68.45.113):
In Reply to: No 1 plug mis-fires when warm? on a 140? posted by NawlensGator on May 03, 2009 at 05:23:13:
I guess next step would be put a set of points back in (you did save some, and the terminal post right? I did) and see what happens. It just seems weird that the module would 'know' it is on No.1 and decide to fail to send a pulse to the coil.. You would think it would fail equally on all cylinders. For chuckles, you might try taking the magnet thingy off the distributor cam and turning it 180 degrees to see if the failure changes plugs. I have the Pertronix on a 140 for four years now with no problems. I am curious to see how this turns out.
This post was edited by TheDurk at 07:33:39 05/03/09 2 times.
