Re: No 1 plug mis-fires when warm? on a 140?
Posted by John G. Hasler on May 03, 2009 at 07:35:04 from (64.91.34.95):
In Reply to: Re: No 1 plug mis-fires when warm? on a 140? posted by TheDurk on May 03, 2009 at 07:12:20:
> ...you might try taking the magnet thingy off
> the distributor cam and turning it 180 degrees
> to see if the failure changes plugs.
Good idea. Also try changing the plug.
Could also be that the plug is fouling for some reason.
