Posted by Janicholson on May 03, 2009 at 10:00:16 from (71.87.46.76):
In Reply to: H won't turn posted by Bleeker on May 02, 2009 at 21:44:58:
If you can turn ut at the crank pulley W/O plugs in it, you are good to go. That is an indication that things are OK in a new engine. Jumper cables on a 6 volt system will not do the trick (especially the 8gauge booster cables often described as jumper cables. With the distances involved it would take OOOgauge welding cables to do a good job. The tractor needs at least ))gauge cables installed for normal operation, and those are as short as possible. It is fine, Put the battery in the box fully charged, and it will crank well. JimN
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
