Re: IH300 Utility IPTO problem
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by JK MN on April 10, 2000 at 08:37:14 from (207.242.199.136):
In Reply to: IH300 Utility IPTO problem posted by PD on April 09, 2000 at 13:07:38:
PD, Are you pulling the lever into the locked position? I assume you are. Then the first step is to adjust it like other posts stated. But if adjustment doesn't help, you do not have to split the tractor, as the pto unit is self contained at the rear, and it can be easily removed as a copmlete unit, and either you can O/H it, or you can carry it to a place that can O/H it. Good luck, and hope adjustments do the trick.
Post A Followup
: Re: Re: IH300 Utility IPTO problem
