Farmall M radiator
Posted by Andre (NE) on May 03, 2009 at 21:00:13 from (204.26.91.110):
Hi everyone; my M's cooling system is acting up. Here is the sequence of events
1. Last summer I installed a thermostat. Before that, the temp gauge would never move. With the thermostat, the tractor warms up to operating temp (190) and seems to run better.
2. This spring, the radiator started spewing coolant out of the overflow tube. It seems to do it when the RPMs are low. If I move the throttle UP, the coolant flow out of the overflow tube would tend to stop or slow down.
Somehow, it seems to be thermostat-related to me.
I have the radiator taken out. I thought it was leaking, but once I took it out, I realized that the place where I thought it was leaking is actually the overflow tube (left bottom corner).
What do you guys think?
Today's Featured Article - Tuning Up Your Tractor: Cooling and Fuel Systems, Hoses and Belts - by Curtis Von Fange. Our tractor is coming right along. The old oil and filter has been taken to the recycler and the air filter replacement has breathed new life into our motor. Let's take a closer look, now, at the cooling system since it has to work so hard in the summer heat. Cooling systems can be real cantankerous in their old age. Radiator cores clog up with rust, lime or other mineral deposits and the fins clog up with weed seeds and debris. The metal headers slowly corrode away from years of use and ... [Read Article]
