Re: H won't turn
Posted by Owen Aaland on May 04, 2009 at 01:01:51 from (65.165.246.54):
In Reply to: H won't turn posted by Bleeker on May 02, 2009 at 21:44:58:
Jumper cables alone are just not going to cut it, no matter what gauge wire they are made with. The clamps and the ends are going to be the limiting factor. A clamp is not going to have enough surface area in contact with the starter terminal to flow enough current to crank your engine.
If you can turn the engine by hand with the front pulley it would indicate that the drag is completely normal for a fresh overhaul.
