Farmall front rockshaft arm/lift link hook-up
Posted by Scott A Johnson on May 05, 2009 at 08:31:21 from (75.44.52.165):
Not sure on this one so here it goes, How do the rockshaft pins on the left side front rockshaft arms connect to the lift link on a Super A? Does the rockshaft pin go in from the backside and thru the hole on the lift link and then thru the outer hole on the rockshaft arm? What about the cotter pin? The pin does not go in all the way as it bottoms out against the sheave on the rockshaft arm. Almost seems a hole should be drilled through that sheave/plate on the rockshaft arms and the cotter pin sits in between the sheaves of the inner and outer rockshaft arms? Thanks for some direction on this one.
