Re: Questions; Putting loader on a Super M
Posted by mkirsch on May 06, 2009 at 05:18:43 from (64.80.108.55):
In Reply to: Questions; Putting loader on a Super M posted by CenTex Farmall on May 05, 2009 at 19:34:32:
With two-way cylinders you should be okay on reservoir.
Definitely reduce the relief valve to its minimum. Probably 1500psi is as low as it will go. The relief valve in the hydraulic reservoir under the gas tank will kick in first, but it never hurts to be double-protected.
