Re: 12 Volt Conversion for Farmall H
Posted by Johnny Lawson on May 06, 2009 at 05:46:37 from (161.235.198.164):
In Reply to: Re: 12 Volt Conversion for Farmall H posted by Johnny Lawson on May 05, 2009 at 10:12:54:
I am installing a new alternator on my Farmall H and I want to make sure I have the connections right. The battery wire that leads from the alternator terminates on the plus side of the ammeter? And the yellow wire that plugs into my alternator that wire terminates on the ignition switch? Also the wire that leads from the coil to the distributor is on the negative side of the coil. The positive side of the coil runs to the 6-volt resister, is this correct, does it matter which side of the coil goes to the 6-volt resister? The tractor has always started and runs good. Thank you for your help. Johnny
