Re: 12 Volt Conversion for Farmall H
Posted by Janicholson on May 06, 2009 at 07:49:44 from (199.17.6.128):
In Reply to: Re: 12 Volt Conversion for Farmall H posted by Johnny Lawson on May 06, 2009 at 05:46:37:
The wire going to the coil from the resistor should attach to the same polarity sign that it is. Thus if positive is hot, the wire connects to the positive terminal of the coil. The negative side attaches to the distributor/points/condenser, (which is negative on a negative ground)
The wire from the alt big terminal attaches to the load side of the amp meter.
I say this because the amp meter manufacturers do not mark them clearly, and they can be used for either polarity.
Assessment of Amp meter:
The supply side comes from the battery non grounded terminal (usually from a heavy #10 wire going to the starter switch big terminal which is connected to the hot battery cable). The load side of the gauge is connected to the light switch, the Voltage regulator (on a generator based system) or the big terminal of alternator (your case), and to the ignition button/switch/key.
If the lights work, and are attached to the load side of the amp meter, turn them on with the tractor off. If the meter swings left, to Discharge, it is correct. If it swings to the right, it is on backwards and just switch all the wires from one terminal to the other. This will make it read correctly.
If the lights do not work, watching the Amp Gauge carefully while turning on and off the ignition will also show the meter moving to the left (discharge) when on.
Good luck, and keep us informed with a new topic. JimN
Today's Featured Article - Talk of the Town: Winterizing Engines - To Drain or Not to Drain? - by Russ Berry. What is this strange attraction I have to equipment and machinery? How did I get this way? I came from the suburbs and own a small horse farm in rural Loudoun County, Virginia. You can call me a "weekend farmer." The local farmers do. Does it bother me? No. I am just happy to have their friendship. At least the word "farmer" is in my title. But what is the attraction? How can I explain the sensation and exhilaration I feel when I turn the key and hear the engine come to life (most ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
