Re: How to remove PTO on H
Posted by ARF on May 06, 2009 at 08:30:10 from (216.168.95.142):
In Reply to: How to remove PTO on H posted by ARF on May 06, 2009 at 07:26:18:
Actally the reason I am removing the PTO is to try and fix the engagement lever. Currently I can pull the engagemnt lever all the way out and see where a pin that goes through it is sheared off.
