Re: How to remove PTO on H
Posted by Janicholson on May 06, 2009 at 08:50:41 from (199.17.6.128):
In Reply to: Re: How to remove PTO on H posted by ARF on May 06, 2009 at 08:30:10:
I will bet that the issue is that internal lever that is now not connected. It may have dropped down confounding the removal. If looking in the hole does not provide a way to turn the inner lever, It might be able to be fished up from a drain, or Pulling the top off (Sorry about that last idea) JimN
