Re: what is the difference between these two thermostats
Posted by Bob on May 07, 2009 at 08:18:57 from (69.178.228.68):
In Reply to: what is the difference between these two thermostats posted by Andre (NE) on May 07, 2009 at 08:07:02:
Many of us tractor guys think a 180º thermostat is just fine for old tractors. One of the reasons for the cooler thermostats in the "old days" was not to boil away the alcohol-based anti-freeze, no longer a problem.
Warmer engine temps = less oil contamination.
