what is the difference between these two thermostats
Posted by Andre (NE) on May 07, 2009 at 08:07:02 from (199.125.14.2):
So, I want to replace the 180 thermostat in my M with a 160 which is what should be in there in the first place.
But, which thermostat should I get:
third party image
or
third party image
what is the difference (other than the physical appearance)?
My M is the "early" M.
