Re: what is the difference between these two thermostats
Posted by Underwood on May 07, 2009 at 08:30:02 from (70.209.241.39):
In Reply to: what is the difference between these two thermostats posted by Andre (NE) on May 07, 2009 at 08:07:02:
Andre, I just bought one from CIH for a "49 M that looks like the one in your top illustration. My question is this, the "housing" around the temperature sensing button (on the right in your illustration) was stamped with an arrow and the words "To Rad" that indicated the housing with button should be on top, up in the pipe going to the radiator rather than down, on the engine side like every other thermostat I have ever seen. Thats the way I installed it but what is the board"s opinion, is this correct?
