Re: Farmall M Voltage Regulator
Posted by Melvin on May 07, 2009 at 21:24:55 from (4.152.108.205):
In Reply to: Farmall M Voltage Regulator posted by Melvin Ware on May 02, 2009 at 11:53:42:
Thanks for the information and tips on troubleshooting my charging system. I was obviously under a misconception of exactly how this thing is designed to work. The weather finally cleared enough to get back to troubleshooting and I found that by jumpering the voltage regulator "F" terminal to ground, it suddenly starts working. According to what you guys are saying, this would indicate a bad voltage regulator. My question is, will any generic two pole regulator designed for a "Class A" charging system (NAPA, AutoZone, Advance, etc.) work here or must I order one specifically for a Farmall Model M Tractor? I want to be sure to maintain the proper charging voltage output.
Also, since the battery provides no excitation to the generator in a Class A charging system, does this mean the generator is "self excited" via residual magnetism? Is this the reason for "flashing" or "polarizing" the generator?
In all my years I've never had to work on a voltage regulator system so it's great to finally understand and appreciate how all of this works. Thanks for your help.
