Hi there... I just did the same thing Friday night. We had previously taken the engine and bolster from the tractor, and getting the center section off like you described was a challenge. What finally worked for us was getting successively larger wedges in between the two cases to pry them apart. Most likely they have been together for 67 years and are just stubborn. We used gasket scrapers, wonder bars, and different chisels. wedge them in tight, then apply pressure opposite the wedge...if the wedge is at the bottom of the case, push down on the top...if you put it on the top, lift up on the bottom. It was a very stubborn one, but it came off! Good luck!!!
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
