Re: Removal of Clutch Housing from Transmission case on H
Posted by pete 23 on May 10, 2009 at 18:17:02 from (173.87.1.12):
In Reply to: Removal of Clutch Housing from Transmission case on H posted by Farmall Bob09 on May 10, 2009 at 17:24:57:
The dowels are not threaded into rear case, but you can put a nut on the dowels and you may be able to pull dowel out or it will just turn in case which would indicate it is not all that tight anyway.
