Thanks for the info. Hugh: I would like to add a loader asap, so when the pump was found to be bad, I decided to go ahead and put the larger pump in. Charles: I have pulled the whole thing off a couple of times to figure out the routing of the oil through the circuit. The port on the plate where the pressurized oil leaves the remote valve goes to the large plug at the bottom of the cover plate. The port that would seem to be for the return oil is plugged off and there is no channel carved in the cast either. It seems that this plate was meant to block off the return port and send the pressurized oil out through the large plug. I thought maybe someone had seen this configuration before. Any help is appreciated.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
