Posted by Joe A. on May 10, 2009 at 19:31:01 from (67.72.98.45):
Is this outer plate a power beyond cover plate? Just put a new 17gpm pump in and the flow to the auxillaries is dead-heading so hard it is nearly killing the engine at idle. This valve is an open neutral two way valve with float. When I say it is dead heading, that is with lever in any position. It will lift my haybine very easily now, but really loads the engine while the hydraulics are not being used (Power steering works very well also). If this is a power beyond add on, I assume I can run the output of this plate to sump, or buy a normal cover plate. It is worth noting that this tractor was owned by the state of Indiana for many years before my grandfather bought it around 1984 and may have had a loader on it or has been plumbed for multiple remotes. It is a 1964 International 504 (Utility).
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
