Re: IH 504 Hydraulic valve - What is this for????
Posted by mkirsch on May 11, 2009 at 04:49:13 from (64.80.108.55):
In Reply to: IH 504 Hydraulic valve - What is this for???? posted by Joe A. on May 10, 2009 at 19:31:01:
This is an open center system, so the oil should be just dumping straight back into the sump after flowing through the valve bank.
If that is a power beyond block, then it should be dumping back into the sump. It should NOT be capped off. That will burn up a hydraulic pump very quickly. That may explain why the old pump was bad.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
